TwinTurbo.NET: Nissan 300ZX forum - how can the engine lean-out if combustion isnt taking place? (n/m)
on February 26, 2013 at 3:09 PM
Haltech is documented well on their forums and software
posted by sdhsbaseball
on February 25, 2013 at 08:54 PM
Considering buying Racelogic Traction Control.
1blackz
20:33:39 02/24/13
Tires? Based on mods, I don't see how you could have issues
PiotrC70
20:48:51 02/24/13
Re: Tires? Based on mods, I don't see how you could have issues
1blackz
20:56:15 02/24/13
Wheel and tire set up? Alignment specs?
Evan(CA)
21:00:20 02/24/13
Re: Wheel and tire set up? Alignment specs?
1blackz
21:07:50 02/24/13
Need to know your alignment specs (camber in particular)
ttsmokin
21:15:46 02/24/13
Re: Need to know your alignment specs (camber in particular)
1blackz
21:22:34 02/24/13
+1 I nearly zero-ed my camber: made a world of difference (n/m)
Zvil (FL)
21:31:32 02/24/13
What are you alignment specs? TT or NA gearing?
Evan(CA)
21:22:48 02/24/13
Re: What are you alignment specs? TT or NA gearing?
1blackz
21:31:51 02/24/13
I've noticed that the 2.5" dp/tp and stock ic/inlet pipes
Evan(CA)
21:42:16 02/24/13
Skeptical to say the least.
The Hawk
09:17:30 02/25/13
Looks like from your profile you have stock turbos?
ttsmokin
20:58:01 02/24/13
Re: Looks like from your profile you have stock turbos?
1blackz
21:04:55 02/24/13
Doesn't the Haltech ECU have TC?
NextZ
21:21:07 02/24/13
It's not traction control per se. Has to be programmed
ForceFedTT (SoCal)
21:54:13 02/24/13
incorrect.
Antihero
08:47:24 02/25/13
Eh, I don't see Haltech bragging about their Z32 ECM
ForceFedTT (SoCal)
14:58:44 02/25/13
the ECU absolutely does have traction control built in
Antihero
15:59:11 02/25/13
True. The tranction control capability needs to be
ForceFedTT (SoCal)
18:41:28 02/25/13
he was the second person to directly quote haltech
Antihero
16:00:31 02/25/13
maybe your diff went bad?.... 1 tire fire? (n/m)
Zvil (FL)
21:34:50 02/24/13
Strongly recommend RLTC after checking drivetrain
OverZealous (CT)
22:38:10 02/24/13
Where did you get (vendor) your RLTC? (n/m)
1blackz
02:30:41 02/25/13
2nd hand. Here on TT.net. (n/m)
OverZealous (CT)
18:36:05 02/25/13
You are overlooking a traction issue
Dane (Houston)
23:02:16 02/24/13
Re: You are overlooking a traction issue
1blackz
02:37:40 02/25/13
NT-01 = 100 TW, great but won't last long on street. (n/m)
ZonaZ
11:48:00 02/25/13
A lot of "modern" RWD with a lot less than 417 rwhp are
ConVerTT
00:23:16 02/25/13
Thank You! That's just what I was thinking. (n/m)
i_s_64
00:34:25 02/25/13
it is a nice piece of gear, although it does require being
00:58:52 02/25/13
Hey LJ!! How's it going?
1blackz
02:27:41 02/25/13
I wouldn't say "planning" so much as "procrastinating"
04:18:48 02/25/13
RLTC doesn't require tuning at all...
OverZealous (CT)
18:45:25 02/25/13
Re: RLTC doesn't require tuning at all...
1blackz
20:17:04 02/25/13
if I had to guess....
14:58:45 02/26/13
hm, not disagreeing, but mine was way over-aggressive
14:43:14 02/26/13
Yes, that would be nice if someone could answer my question. (n/m)
1blackz
02:26:10 02/25/13
Re: Yes, that would be nice if someone could answer my question.
OverZealous (CT)
18:52:37 02/25/13
http://www.jordaninnovations.com/
03:03:38 02/25/13
Thanks Bernie!! (n/m)
1blackz
09:31:38 02/25/13
Reply I got from them today - feel free to contact Jeff @
15:28:25 02/25/13
Good info - thx for posting it (n/m)
ConVerTT
12:28:13 02/26/13
with the price of RL, a standalone ECU starts to look good
Antihero
08:44:19 02/25/13
RLC Traction Control =/ to Haltech Traction Control
sdhsbaseball
10:40:11 02/25/13
I know the haltech is not tested or documented well
Antihero
10:58:11 02/25/13
sdhsbaseball
20:54:24 02/25/13
I searched the haltech forums and came up empty.
Antihero
23:38:53 02/25/13
Here, I can post some software pictures if you want
sdhsbaseball
23:43:46 02/25/13
More
sdhsbaseball
23:52:08 02/25/13
how can the engine lean-out if combustion isnt taking place? (n/m) -
15:09:11 02/26/13
that's half the fun of these cars, you have to actually know
moxie (SF)
19:22:43 02/25/13
It's funny 'cause it's true. (n/m)
Antihero
23:41:16 02/25/13
It is but I feel kind of bad about wanting my teen drivers
ConVerTT
12:31:13 02/26/13
why feel bad. a TT is a terrible car for a teen driver to
moxie (SF)
12:51:17 02/26/13
